how much to fix?
saywin
Fletch
I have a transmission leaking at the rear when sitting on an incline and running. Does anyone know how much this should cost to fix? Thanks in advance.
have you check your gasket? where is it leaking from ? on an incline tells me your tranny gasket could be bad , cost maybe $20
If you can't get it figured out I'm am about 45 minutes away from you and have all the stuff to reseal it.
Also check the speedo cable connection.
