Hey guys. I just wanted to know how often you get down far enough on the gas to make the little needle on your boost guage move : ) Every day? multiple times a day? hardly ever? how often do you do full throttle blasts down the road, and how much boost are you running in general? Im worried about the durability of my motor. I mean, i know that you guys on here all list super fast dragstrip times, but is that the only time you stomp on em? I never get down on mine, i fear that boost will damage it, especially not knowing EXACTLY whats in the bottom of my engine. I know it has good oil pressure, 20 psi hot idle or so, no oil cooler, when it gets really hot like pulling a 4 mile hill through the mountains it will drop to about 14 psi, which scares me. I know it doesnt make too much noise, its smooth, but i just cant see these engines holding up to repeated blasts all the time. i havent gotten more than 5 psi boost in around 8 months or so. I just feel that im pushing my luck. Anyone know how long these things will last under pressure ike this?
The bore is perfect std no ridge, perfect compression all across of 145 psi. polished rods, all stock pistons, but one was replaced inside before i got to it, and it looks different??
Should i worry or will it hold up to abuse like i wouldnt believe.
Thanks guys
Thanks guys
