- Dec 26, 2010
sorry guys i guess the gto slideshow innt done yet but the belair slideshow has two parts to it be sure to catch them both. ill try to get the gto show updated asap
SignUp Now!i will try mat.
thanx joe![]()
This may help you some Kaj. My car but not yet finished.:frown:
http://www.turbobuick.com/forums/before-black-non-sfi-tech/322115-finally-got-some-time.html
once i cut away the rust, what's the easiest way to fill in the holes? metal? fiberglass? holes are lower, rear quarter panels and the corner where the rear window meets the trunk.
do i grind away all the rusted areas before filling? or can some of it be halted and saved?
so far, charlie has the best post for rust repair. when it warms up here i will try to make a post how to fix rust. if need be i will fix a old fender to show people how to fix rust.This may help you some Kaj. My car but not yet finished.:frown:
ouch. mine isn't THAT bad. i was hoping to not have to weld in new panels, as i am not a welder type o' person. LOL
i was kinda wanting to just grind away the rusted metal and use fiberglass or lead to fill in the holes.
i'm stuck with the car, either way. may as well experiment!
Thanks Matt.:redface: I did a lot of reading before I attempted it though.:biggrin:
you don't have to weld, you can always buy that panel glue stuff and glue in the patch. i have used the glue for puting a quarter panel on a truck bed. i would just weld it tho. some body guys swear by the glue i am on the fence with the stuff. your choose what is best for you.
I thought about the glue but I wanted mine to be permanant. Glue doesn't always hold up so I didn't want to take the chance.
charlie today glue r awesome product.
even today airplane r glue .
Not argueing Miguel. Click on the link I provided and see what you think about my body work.:biggrin: I think you'll understand why I went with welding.:smile:
I would of gone that same rout.:biggrin: man you did alot work on that car, most body guy would of fine other rollor . KUDO to you my friend great save.![]()
