I have an extra hot air intake laying in my basement. What can be done to it to make it better than stock? I'd like to keep it stock appearing. Can it be modded to use a larger turbo? Is there anything that can be done to the throttle body as well or is there a better one out there to use on our cars?
Thanks, Steve
Hey Steve.
Anything is possible, with enough time and $$$.
The ported intake will yield results, as will the ported TB, and larger turbo.
All modifications will yield positive results, but "measurable" is the key.
Example (without insulting your intelligence)
Some say that coated pistons will increase HP output.
Well, Hot Rod Magazine could really find a real measurable increase on a dyno.
So, how do racers, who have not completed the "back/back dyno testing" make such a statement?
And, is the increase in HP worth the $$$ and effort? (In Pro Racing, yes, but for the average enthusiast????)
So, I think what Brad is saying, is the "most SOTP measurable benefit" will be if you do it all at one time.
I "Ass-U-Me" that if you continue to run stock boost levels (8-10PSI) the intake, TB, turbo and heads are not much of a "Butt Dyno" improvement.
Hope this helps.
