Here are the only pics I could find.
I should have taken more.
As you can see as I could get at fasteners, I removed bolts and moved things around & first took the wheel well liner off, then the fender and last the fender liner in this case (as the bolt at the door jamb box location was impossible. Well not impossible - about two minutes with a hack saw and everything was off.) :biggrin:
I am undoing the carcass with the idea that it will help me in reassembly - fingers crossed!
HTH - Bob
