How to Perform a Compression Test
87MUSL
Stupid question.....but I've never performed a compression test on my GN b4. Trying to diagnose a blown headgasket.
Do I....
(1) remove all spark plugs and from engine
(2) install pressure gauge in cyliner being tested and crank over engine for 4-5 seconds with throttle in WOT position.
(3) record value...all cylinders should be within 10-15% of one another.
Does this sound correct?
Thanks in advance.
-Mark
I think you also want to disconnect the orange ecm wire close to the battery and take off the up pipe and put a screw driver in the tb to hold the "butterfly" open to duplicate wot.
HTH
Originally posted by Just a Six??
Why does throttle have to be at WOT? What if you do it without touching the Throttle??:confused:
You will create vacuum in the intake and the numbers will be lower. Not a big deal since you are looking for constincy between the cylinders and not a specific number.
test
Remove all plugs---- disconnect ecm---hold throttle wide open---crank until it HITS 4 times on the cyl. you are testing. The warmer the eng. the better.
Not trying to hijack ya, however same questions...
how much of a difference does it make if you don't take out all of the other plugs? I recently did mine and seen 155 - 165 psi? I didn't realize I had to take the other plugs out. I did have the throttle open though.
It just makes sense. You're gonna do all the cylinders anyway, and the empty plug holes make it easier on the battery... ;)
