How to remove really old rubbing compound
Mike E
Mr. Badwrench
I have a few spots on my car where there are remnants of really old rubbing compound or wax or something. I originally thought it was primer showing through where the masking wasn't tight to the trim, but when I swapped a fender this weekend! I found more inside the fender. It's in the drip rail, crevices around the window trim and gaps around the trunk. It is as hard as concrete and I can seem to remove it by rubbing or with a fingernail.
Is there something that will chemically soften it without harming the paint?
Just wet it and get s little detail kit from the parts store. It comes with some fine brushes and some rubber tips also. Also some good foaming glass cleaner to. Can usually wipe out with a rag..
I tried to scrub it with a wash mitt when I washed the car yesterday and it doesn't budge. I've tried an old toothbrush and soapy water and a clay bar and quick detailer. It's tough stuff.
Ya it's a pain. They also have some wax remover also my try spraying using it and more scrubbing. Its a chemical but not harsh at all.
X2 Bison.....More wax or compound will remove the old stuff safely and fast...
Apply wax/compound , then remove damp, don't let it dry....same method works on rubber trim.
Thanks for all the ideas. Most of what is left is deep in crevices or in pits in the window gutter, so I can't get to it easily. There is also some on the quarter window rubber. If I can get it all off, this car will have slow quality paint. Someone in the past must have spent a pretty penny painting the car.
Hard to reach places I use a dollar store paint brush that I cut down with scissors
