How to remove Tranny??????
ProjectWE4
C. Horel
Hey guys I need to know how to remove the tranny in these cars. Can anyone tell me how to and any tips or tricks to use while im at it. Im removing the tranny my self because the people just suck. Well Im removing it because ive officially went through the third tranny last week in 13 months, and the people here dont know how to fix these type of trannys so its going to be soon sent to someone that knows how. But if anyone could give some pointers on how to drop it that would be awsome, and thanks for any advice guys.
chris
- disconnect the TV cable at the throttle body
- remove dipstick from tube
- unplug electrical connector and speedometer cable from driver side of transmission
- remove shift cable/linkage from transmission
- remove converter dust cover (10 mm)
- remove three torque converter bolts and push converter back into transmission (15 mm)
- remove cooler lines (7/16" line wrench)
- remove TV cable (10 mm)
- remove driveshaft
- remove 15mm nut holding transmission mount to crossmember
- remove four crossmember bolts (15 mm)
- jack up transmission and remove mount & crossmember.
- lower transmission and remove the six bellhousing bolts. (long extension, swivel & 9/16" socket)
Take your time and be careful. When reinstalling, be sure that the converter is fully engaged in the transmission and use some thread locking compound on the converter bolts.
