rickringle01
- Jul 12, 2007
Have a question re: replacing rear seal. With the engine in the car, I was told that this could be done by dropping the oil pan. My question is can the pan be removed without lifting the engine? I was also told that you remove the rear main cap and the seal is in 2 pcs. My second question is that when removing and replacing the portion that is located in the block do you merely push the old seal out and does the new one push in w/o much technique. Lastly, where can I locate a good cork oil pan gasket?
