Its been a bit for me since ive done it..5 years?
The trans can stay in the car to see if it has a non lockup valve in it.
You probably should post in the trans section for the best answer
Remove the TCC solenoid, look in the hole, find the retaining c clip that will need to be removed. Pull the clip out, and there will be a round flat piece of metal,
Once you remove the round piece, there should be a long valve with 4 or 5 glands / ribs on it with a green or yellow spring.... That is the stock TCC lockup valve.
The non lockup valve is a slug instead of a valve with glands, and it also has a 1/8th inch round SPACER to take up the distance between the round flat piece and the slug
if there is a long thin 1/8th piece of metal to space out the distance inside the hole under the TCC solenoid, then it has the non lockup valve installed...
Honestly, i think if you try and lock a convertor with a nonlockup valve, bad things will happen inside the tranny... I think,... I dont have first hand experience, but know a guy who did, and the tranny was fubar.
BW
