streetknight
DCVING
- May 26, 2001
First off, I'm talking off of the car. Talking about the ball and spring kind. This is the idea I have and please tell me if you think this would work.
Here is what the setup should look like.
Ok, so when the controller sees the "set" boost pressure it blows the ball off the seat and allows the "set" pressure to exit the outlet to the Wastegate actuator. Correct?
I want to mock this up on the workbench. Let's say that I put compressed air that is regulated to 20psi to the inlet of the controller. I then adjust the screw until 20psi will not blow the ball off the seat and allow air to flow thru the outlet side. Then back off the screw until it does let the 20 psi thru. A boost gauge hooked to the outlet side.
SO, If I have 20 psi going in and 20 psi going out to the boost gauge, would that mean I'd have 20 psi if I put it on the car at this setting?
TIA
TIA
