Dec 17, 2003 #1 K Kyle F Addicted to Boost Joined May 24, 2001 Messages 606 What do you do to test the coil packs? TIA
Dec 17, 2003 #2 G GNSCOTT open faced club sandwich Joined Jul 10, 2002 Messages 1,816 Caspers coil pack tester. http://www.casperselectronics.com/cgi-local/store/commerce.cgi?
Dec 17, 2003 #3 1 1ARUNEM On Lucky #7 Joined May 23, 2001 Messages 1,249 As a general test you can use an ohm meter.. Take a reading from each coil, front and back terminal. Reading should be somewhere between 11k to 13k ohms.. Goodluck..
Dec 17, 2003 #4 K Kyle F Addicted to Boost Joined May 24, 2001 Messages 606 From each terminal, you mean pick the far left in the front, and the far left in tha back and I should get a reading? What if you get some High Resistance readings? Does it matter if the coils are on the car or not?
