How To Tighten Window Crank Regulator
PaulRV6
I have a manual crank window that the regulator has too much play in the pivot point. Is there a way to tighten up the rivet (assuming that is what it is) where the fork arms pivot. I have asked a number of different people but no one seems to have an answer. Thanks
paul
Paul I have a few manual window tracks on hand.I can check to see their condition if you would like.If not is there a way to drill out the rivot & replace?
Yes Brian, I would appreciate it if you could check the ones you have for the amount of play in the scissor joint.
That is what I am trying to find out, if the rivet can be tightened or replaced with something else. Thanks much.
paul
