how to wire 3 bar map
ssleeper94
will it run?
I have an antique gen iv accel in teh car and i belive the map was wired in wrong. can somebody give me the correct wiring for it, i know it needs a signal from the maf but other then that i need help
Brian, I assume its for your DFI. The easiest thing to do is buy the harness from Caspers for about 25-30 bucks just plug in and go. The map sensor needs the wire connections from the TPS and the mass air.
HTH
Prasad
