How's my line pressure?
jarredsoon
I just installed a PTS Xtreme 200-4r with a 9/11 TCS LU converter.
I was testing line pressures and the low reverse concerns me. Is it a problem?
NO TV. FULL TV
P. 90. 275
R. 150. 275
N. 90. 275
4. 90. 270
3. 90. 265-275
2. 275. 275
1. 270. 275
I think the 150 for R is below the minimum. Does this look like a problem??
With the trans in 4 and the rpm just over 1000 the no tv is 90 and tv is 94 and when I push slightly on the cable line pressure rises.
Jarred
2004R Pressure Test InfoTo perform a pressure test on your 2004R is not hard and can supply lots of info if you are having a problem. You will need a 90 deg. fitting 1/8" pipe to -4. You will also need a pressure gauge that goes to 300 psi. The pressure tap is located on the left side of the transmission above the linkage. Typical pressures of a healthy 2004R listed below. I have also listed the minimum required to for decent transmission life. The test should be performed with engine RPM slightly elevated to around 1200 RPM or more. Full TV requires the TV cable to be pulled out as far as it will go. Dont get to hung up on the pressures in Park as some VBs do not boost in Park and some do. The other gears are very important.
Excellent pressure Minimum
No TV / Full TV No TV / Full TV
P 90 275 70 225
R 230 230 200 200
N 90 275 70 225
4 90 275 70 225
3 90 275 70 225
2 250+ 250+ 225 225
1 250+ 250+ 225 225
Yes I read that on the EA website. My question is should I be concerned about the 150 (no tv) in Reverse?
