109 Block, standard bore, line bored,, decked,, o ringed,, 3 steel mains,,$1500.00 gn1 heads $1500.00 with TD roller rocker,s 1.65 RATIO, K1 rods new still in the box, wiseco pistons new still in the box, the rods were $564.00 pistons were $649.00 the file fit rings were $109.99 used steel 3.400 crank turned 10/10 on the high side $500.00 3 steel mains 280.00 arp main studs 55.00 total is $5,212.00 my lose your gain $4500.00 takes it all.I will have Nye,s BUILD A CRATE TO SHIP EVERYTHING,you take of frieght 765-744-6115 Kevin,
