>Let's make sure I am understanding this correctly. If you put a straight edge accross the freeze plug boss horizontally, it hits nothing? The casting around the cyl bore doesn't stick out
past that level?? The 5/16 dimension doesn't sound that far off.
Yes that's right, the "Mt Everest" edition freeze plug boss extends out past the case there. When I get done with the trans mockup (hopefully today) I can then hoist the motor out a bit and get better info. Maybe a pic or two as well, if I can line up a digital cam.
>How much space is there at the top edge of the mount, right in the center of the milled scallop on the mount to the edge of the casting around the cyl bore?
I'll check it out today.
Seems like if there's variance in the freeze plug boss heights, and if the mounts have to "reference" off the bosses then there's going to be some substantial problems to overcome. Is there any way to get it work right without having them bump up against the bosses? In other words just cut that portion away?
TurboTR
TurboTR
