I was wondering: If it is more wise to take the "rear" channel pre-amp output of the head unit (JVC kd-sh99) and send that to the sub amp, or use the dedicated "sub out" pre-amp out?
The sub out has a separate volume control from the "main" volume and it has a built in low-pass filter (not sure what the roll-off is though).
I was thinking, that for proper gain setting, letting the "main" volume control everything without having an additional volume control for the subs, aside from the amp gain pot would make things easier.
I have a Kicker ZR240 amp with a SWX crossover set at 80Hz.
I haven't set my gains using a scope yet...i'm in the process of getting one. In terms of "gain", when I listen to different tracks I wind-up adjusting the dedicated "woofer volume" at the HU to raise or lower the sub output...
Any thoughts?
Any thoughts?
