Huge pro-touring project sellout
87-TURBO-T
I was going to go the pro touring route with my 87 T but have had a change of plans. here's what I have. pics will be up later today.
1) new set of 4 staggered NZO pino-R wheels with correct billet spacers. 18x8.5 & 18x10. also new set of locking lugs. front tires are used michelins with about 40-50% tread remaining, 245-40-18. rear tires are new and have not been mounted, cooper zeon 275-35-18. $1000+ shipping.
2) 2003 z06 front calipers. off a 63k mile car. $180+ shipping.
3) 2003 z06 rear calipers off same car. currently waiting on rebuild kits to arrive. boots looked dry rotted a bit. will be ready to use. $120+ shipping.
4) new in box rear bilstein shocks. $100+ shipping.
5)2003 s10 blazer 2wd spindles & hub bearings. dont know the condition of the bearings as they were bought from a wrecking yard. $125+ shipping.
6) 36mm f-body sway bar with NIB energy suspension greasable poly bushings. $100+ shipping.
7) new moog 5658 front springs. one was partially instally then removed. $60+ shipping.
8) new global west 1.5" drop rear springs. $125+ shipping.
9) fender to core support F-41 braces. $35+ shipping
10) f-41 front chassis braces (x-member to frame horns) $40+ shipping
11) new kirbans tubular rear seat brace kit (4 bars) $50+ shipping.
I'll take the shocks if they are not spoken for. Shipping to MD?
If Tnt or jose doesn't take the rear seat braces i will. And Kirban's sell's the fender to core support braces for $30 so if you'll do $30 shipped on those i'll take them.
Well it looks like everything is up for sale. last night I had the rear tires mounted and the idiot at the tire store accidentally clamped the inside of the outer lip on one rim. it left 2 vary small "divots" in 4 spots around the rim. its really not that noticable, but its there. I will knock $100 off the price. also the front spacers are hubcentric for the blazer hubs and will not work on stock rotors. if you have stock rotors you will need a set of 1" spacers that are around $60 which I will also knock off if you dont need these.
