Hurricane Sale - Lots of Performance Parts! TA-49, TA-61, & More!
TurboTom72
Boost Addict
Hi everyone! Just finishing my build and selling off my old unused performance parts. All prices best offer and plus shipping. Prices are a little flexible, so don't be scared to make an offer. PM me your zip code and I'll calculate the shipping costs. Paypal accepted, but please add 3% for fees. I am located in CT.
10. ATR Boost Controller. Old School bleeder valve style. Best offer plus shipping.
12. 86-87 Aluminum Vacuum Block. Used. Includes all parts and good used gasket included. On my car when purchased. One port looks to be JB welded to block, but only visible inside and not service affecting. Lists new for $40. $25 obo. plus shipping.
13. Modified 200 AMP stock alternator. Purchased from a fellow board member in 2008 and never used it. It was modified by a amp shop. Has a chrome fan blade and external voltage resistor. Asking what I paid for it. $130 obo plus shipping.
14. Billet Aluminum Adjustable Fuel Pressure Regulator. Used, and needs rebuild. Rebuild kit is $30 if memory serves me right. Kirban sells them for $110 new. $45 obo plus shipping.
18. 3" LT1 MAF Sensor. Works great, just upgrading to a larger Z06 style MAF. Lists new for $180 on Full Throttle. $120 obo plus shipping. Requires the use of a MAF translator!
20. 14" K&N Cone Filter. Has hole in the side for IAT sensor.This is the BIG one! $40 obo.plus shipping.
21. Used set of 2.5" Couplers for intake pipe. $5 obo plus shipping.
22. TurboTweak Classic Chip v5.6 for 60# high z injectors. For a basically stock motor with bolt-ons. $85 new. $65 obo plus shipping.
23. TurboTweak Wideband Alky Chip v6.0 for 60# high z injectors. Timing 23*/21*. V6.1 sells for $130 new. $105 obo plus shipping.
24. ATR Pitbull Chip #HP137A1 for 36# injectors 072596. This thing is old! A true Buick relic! $35 obo plus shipping.
26. Stock Sway-Bar Bushings. Used but in excellent condition. Just removed from my car as I upgraded to a 36mm bar with poly bushings. Best Reasonable Offer.
27. Stock End Link Bushings. Used but in excellent condition. Just removed from my car as I upgraded to a 36mm bar with poly bushings. Best Reasonable Offer.
SOLD PARTS LIST
1. TA-49 Turbo.(SOLD) (GNMexico). Unknown mileage, no shaft play, no smoking. Good entry level turbo upgrade providing 11 sec. power.58mm compressor wheel, Garrett 3 bolt exhaust housing (unported WG hole). Minor contact to compressor wheel(not with housing). More cosmetic than anything! This turbo was on my car when I bought it and it worked flawlessly. I ran it this way for 4 seasons this way with no trouble. Turbo has been sitting on the shelf for 2 seasons now after my upgrade. Polished " inlet bell and WG actuator not included. $450 obo plus shipping.
2. TA-61 Turbo. (SOLD)Unknown mileage, no shaft play, no smoking. Will provide 10 sec, power with the proper supporting mods.60-1 compressor wheel, p trim exhaust wheel in a garrett 3 bolt exhaust housing (unported WG hole). A nasty little stock appearing turbo. Bought from a fellow board member, and run on my car the past 2 seasons. Going bigger. $550 obo. plus shipping. Polished inlet bell, bracket, boost controller and WG actuator not included, but available for extra $$$. RJC Boost controller not for sale.
3. Greddy Profec B Spec 2 electronic boost controller. Excellent condition. All parts included. Purchased from a fellow board member. Worked flawlessly, just too much for my needs. Lists for $350 new. Save yourself a few bucks! $280 obo plus shipping.
4. Innovate Motorsports LC-1 Lamda cable with O2 sensor (No gauge).(SOLD) (Kyle) Brand new in box. Never used. Only opened for inspection. o2 bung included. 5v output for use with any standard O2 Gauge. This setup has stand alone datalogging capabilities. $180 obo plus shipping.
5. VDO 2 1/16" Water Temperature Gauge.(SOLD) (Midnite Rider)100*-250*F scale. Includes gauge, light and sender. $25 obo plus actual shipping.
6. VDO 2 1/16" Boost/Vac Gauge.(SOLD) (TurboHungry) 30 In Hg Vac and 25 PSI Boost Scale. Includes gauge and light only. Used lightly, one stud cut for A-pillar Pod. You buy your own vaccuum line and fittings. $30 obo plus shipping.
7. Autometer 2 1/16" Boost/Vac Gauge Pro Comp Ultra-Lite Series #4303.(SOLD)(1NASTYGN) 30 In Hg Vac and 30 PSI Boost Scale. Complete, all parts included. Used lightly, one stud cut for A-pillar Pod. $60 new from summit. $45 obo plus shipping.
8. 3" ATR Terry Houston Down Pipe.(SOLD)(Dsmith4994)304 Stainless Steel. Internally gated. Worked great. Upgraded to 3.5" so I don't need it anymore. $350 obo plus shipping.
9. 3" ATR Catalytic converter. (SOLD) (ChevMCarlo84)It was on the THDP for sale when I purchased my car in 2006. No more emissions in CT for cars 25yrs. or older. $100 obo plus shipping.
11. TurboLink Scan Tool. Version 4.0.6 with vehicle pack 11. (SOLD) (QwikStop) Great entry level scantool. This is meant to be used with a laptop. Definitely older school technology, but it works great for what it is. Much nicer than just a stand alone scanmaster. It has the ability to datalog, view all the data from the car's ECM, and clear trouble codes. Basically a more primitive version of the powerlogger, just slower updating the data to your PC. Definitely very helpful in troubleshooting our cars. Includes CD with program, and all cords to connect to a USB. I strongly advise using this with a windows XP based laptop or earlier version of windows. $150 obo. plus shipping.
15. TCI 10" Torque converter #243107. Lock Up.(SOLD) (GNMexico). Just came out of my car. I'm going to a 9.5 non-lock up. Summit says its for a 4L60E & 700R4 with a 30 spline input shaft, but it just came out of my BRF coded Turbo 200-4R. None the less, it lists on Summit Racing for $500+. Advertised flash stall rating was 2400rpm. Spooled my TA49 violently! Nice entry level converter. Save yourself some money! $350 obo plus shipping.
16. Champion Racing Aluminum EGR Block off Plate. (SOLD) (1987T)Allen bolt included. Just add RTV and your all set. $20 obo plus shipping.
17. Kenne Bell Oil Pressure Booster Plate Kit Part#KB18213-14(SOLD) (Trixdout) Purchased 08/2000. Brand New, never used, and includes all parts. Used to increase oil pressure. Works on all Buick V6 & V8 engines. Paid $42 new. Time to go! $35 obo plus shipping.
19. Hard Vacuum Lines. The back 2, one goes to the PCV. Very good shape. Best Reasonable Offer.
25. 3" Polished Cold Air intake setup with blue couplers.(SOLD)(Franks86gn)Very good condition. Usual scrape marks underneath. Lists for $85 new on Full throttle. $65 obo plus shipping.
Hi everyone! Just finishing my build and selling off my old unused performance parts. All prices best offer and plus shipping. Prices are a little flexible, so don't be scared to make an offer. PM me your zip code and I'll calculate the shipping costs. Paypal accepted, but please add 3% for fees. I am located in CT. Please bear with me if I don't get right back to you, as I currently have power, but that could be short lived with the inclement weather. I will do my best!
1. TA-49 Turbo. Unknown mileage, no shaft play, no smoking. Good entry level turbo upgrade providing 11 sec. power.58mm compressor wheel, Garrett 3 bolt exhaust housing (unported WG hole). Minor contact to compressor wheel(not with housing). More cosmetic than anything! This turbo was on my car when I bought it and it worked flawlessly. I ran it this way for 4 seasons this way with no trouble. Turbo has been sitting on the shelf for 2 seasons now after my upgrade. Polished inlet bell and WG actuator not included. $450 obo plus shipping.
2. TA-61 Turbo. Unknown mileage, no shaft play, no smoking. Will provide 10 sec, power with the proper supporting mods.60-1 compressor wheel, p trim exhaust wheel in a garrett 3 bolt exhaust housing (unported WG hole). A nasty little stock appearing turbo. Bought from a fellow board member, and run on my car the past 2 seasons. Going bigger. $550 obo. plus shipping. Polished inlet bell, bracket, boost controller and WG actuator not included, but available for extra $$$. RJC Boost controller not for sale.
4. Innovate Motorsports LC-1 Lamda cable with O2 sensor (No gauge). Brand new in box. Never used. Only opened for inspection. o2 bung included. $180 obo plus shipping.
5. VDO 2 1/16" Water Temperature Gauge. 100*-250*F scale. Includes gauge, light and sender. $25 obo plus actual shipping.
6. VDO 2 1/16" Boost/Vac Gauge. 30 In Hg Vac and 25 PSI Boost Scale. Includes gauge and light only. Used lightly, one stud cut for A-pillar Pod. You buy your own vaccuum line and fittings. $30 obo plus shipping.
7. Autometer 2 1/16" Boost/Vac Gauge Pro Comp Ultra-Lite Series #4303. 30 In Hg Vac and 30 PSI Boost Scale. Complete, all parts included. Used lightly, one stud cut for A-pillar Pod. $60 new from summit. $45 obo plus shipping.
8. 3" ATR Terry Houston Down Pipe. 304 Stainless Steel. Internally gated. Worked great. Upgraded to 3.5" so I don't need it anymore. $350 obo plus shipping.
9. 3" ATR Catalytic converter. It was on the THDP for sale when I purchased my car in 2006. No more emissions in CT for cars 25yrs. or older. $100 obo plus shipping.
10. Boost Controller. Old School bleeder valve style. Best offer plus shipping.
11. TurboLink Scan Tool. Version 4.0.6 with vehicle pack 11. Great entry level scantool. This is meant to be used with a laptop. Definitely older school technology, but it works great for what it is. Much nicer than just a stand alone scanmaster. It has the ability to datalog, view all the data from the car's ECM, and clear trouble codes. Basically a more primitive version of the powerlogger, just slower updating the data to your PC. Definitely very helpful in troubleshooting our cars. Includes CD with program, and all cords to connect to a USB. I strongly advise using this with a windows XP based laptop or earlier version of windows. $150 obo. plus shipping.
15. TCI 10" Torque converter #243107. Lock Up. Just came out of my car. I'm going to a 9.5 non-lock up. Summit says its for a 4L60E & 700R4 with a 30 spline input shaft, but it just came out of my BRF coded Turbo 200-4R. None the less, it lists on Summit Racing for $500+. Advertised flash stall rating was 2400rpm. Spooled my TA49 violently! Nice entry level converter. Save yourself some money! $350 obo plus shipping.
16. Champion Racing Aluminum EGR Block off Plate. Allen bolt included. Just add RTV and your all set. $20 obo plus shipping.
17. Kenne Bell Oil Pressure Booster Plate Kit Part#KB18213-14. Purchased 08/2000. Brand New, never used, and includes all parts. Used to increase oil pressure. Works on all Buick V6 & V8 engines. Paid $42 new. Time to go! $35 obo plus shipping.
18. 3" LT1 MAF Sensor. Works great, just upgrading to a larger Z06 style MAF. Lists new for $180 on Full Throttle. $130 obo plus shipping. Requires the use of a MAF translator!
19. 3" Polished Cold Air intake setup with blue couplers. Very good condition. Usual scrape marks underneath. Lists for $85 new on Full throttle. $65 obo plus shipping.
25. Hard Vacuum Lines. The back 2, one goes to the PCV. Very good shape. Best Reasonable Offer.
Pics will be posted soon!
Pics of down pipe to knperformance@hotmail.com
Everyone, sorry for the delay. Just finished getting a good friend hooked up on generator power. Here come some pics of the stuff that was requested so far. I will be contacting everyone in order to keep it fair.
#8 ATR THDP (SOLD)
#9 ATR 3" CAT - Still Good. Passed Emissions summer of 2011 with it (SOLD)
3 inch ATR Hi-Flow Cat.jpg3 inch ATR Hi-Flow Cat  2.jpg3 inch ATR Hi-Flow Cat  3.jpg
#17 Kenne Bell Booster Plate Kit (SOLD)
Guys, Order is as follows on downpipe: Kent86GN, Dsmith4994, knperformance, Franks86GN. Pics are up, and I will be moving in order until sold. More pics of the other parts to follow.
Hi Everyone. Here are some more pics.
4. Innovate Motorsports LC-1 Lamda cable with O2 sensor(SOLD)
6. VDO 2 1/16" Boost/Vac Gauge. (SOLD)
7. Autometer 2 1/16" Boost/Vac Gauge Pro Comp Ultra-Lite Series #4303 (SOLD)
Frank, Downpipe has not sold yet. Dsmith4994 is next in line. I am waiting for his decision. If he passes, knperformance is next, then you. Just keeping it fair. I will keep you posted.
11.TurboLink Scan Tool. Version 4.0.6 with vehicle pack 11.(SOLD)
Aluminum Vacuum Block.jpgAluminum Vacuum Block  2.jpgAluminum Vacuum Block  5.jpg
13.Modified 200 AMP stock alternator
Adjustable Fuel Pressure Regulator.jpgAdjustable Fuel Pressure Regulator  3.jpgAdjustable Fuel Pressure Regulator  2.jpg
15. TCI 10" Torque converter #243107. Lock Up. (SOLD)
19. 3" Polished Cold Air intake setup with blue couplers. (SOLD)
24.ATR Pitbull Chip
26.Stock Sway-Bar Bushings.
