Am I even remotely installing this correct?
I am a novice garage enthusiast. I am installing a Hurst Shifter into my GN. I have recently installed the TH400 seen in the pics below. I am eyeballing everything and trying to install everything the best that I can. I do not help with this, so can anyone please let me know if this is looking right?
In my efforts to mate the stock shifter plate to the Hurst shifter plate, I cut the center hump out and both of the back sides. I eyeballed the height the shifter needs to be in-order to use the console.
I cut the center console to get the shifter to move freely. I had to decide on cutting it and being able to return it to stock form. I did not see anyway around cutting the middle out. Right now the shifter looks to be sitting in a good spot. I can go through all of the gears. I have it zip tied down right now.
I installed the shifter cable. I had to elongate the holes in the cable bracket, for my pan holes are very close to the pan. The linkage hooked up fine. I did not have to bend the bracket to work. I would like to use the shifter bar that allows for reverse lights and neutral start, but I do not see a way to do that with what I have now. I am not a machinist so fabrication is guesswork for me. I plan on modifying a stock console top to work, or I might order one from TR Customs.
Any suggestions?
Any suggestions?
