I have an 84 TR with stock brakes. About a week ago, I decided to paint my master cylinder cover with yellow caliper paint. I re-installed the master cylinder cover and everything was graet for a weeks worth of driving. Yesterday I was coming home from work and I lost most of my brakes. I managed to get home safely. When I checked out the problem, I noticed that the driver's side header and spark plug wires were wet and oily. I thought I had a failure in the power steering line that goes to the hydroboost system. This was not the case. When I took the master cylinder res cover off, it was full on the front part of the resevoir, and basically empty on the back half. I am assuming that when the system was running and pressurized, the brake fluid was forced out of the master cylinder res and it leaked down the sides of the resevoir. Is this possible? Do I now have to bleed the whole system or does the rear part of the resevoir only affect the rear brakes? Or does it only affect only the fronts?
