Guys,
I really appreciate your help. I had Bob at Power Brake rebuild by hydroboost (HB) 5-10 years ago and never re-installed it.
A little background so you aren't totally confused by my actions. I have an 84 GN that I subsequently installed an 87 engine w/intercooler. I installed vacuum booster from NA Regal and GTA 4 wheel master cylinder at that time and also went to B-car 12 " front and Baer rear disc brakes. The vacuum system has worked great for me but I have installed a bigger turbo and high stall torque converter and the rear disc simply aren't holding the car when the turbo starts cooking real good on the starting line at the drag strip.
I thought that re-installing the HB would solve my problems since itgenerates pressure that is significantly higher which SHOULD greatly enhance the rear disc holding ability.
My other options are transbrake (VERY expensive since the tranny MUST be built to take the abuse or boost control (again, expensive). Since I already have the HB...that seems to be worth a shot.
I have e-mailed Bob to see if I can use my GTA master cylinder and to get some other info. Bob has always been very helpful on these systems. He has been working on these systems for many years and I trust his judgement.
Conrad Carter
Albemarle, NC
