Hydroboost
91.5mm
Hello everyone.
I installed a hydroboost setup from hydrotech.Here are the 2 issues I'm having.
First is when turning the wheel the steering wheel shutters and if you put your foot on the brake the pedal vibrates.The system is all bleed but the pump is making a noise like a vibration and the line from pump shaking alot.
Second is the car seems the brakes are draging.Pedal is very touchy.
Is there and adjustment.
Went on Web site on tech but no info.
Thank u
Tony
Just finished a hydroboost install, and this sounds like a bleed problem to me.
Did find old info.I foubd something about the serp belt being a little long and this car has aluminum pulleys.So I foubd that the tensioner was extended all the way.So I purchased a new belt but an inch shorter and it fixed all the issues.
Thank u
Tony
