i have a concern though. the tank doesn't last long for one thing. i made two 21 psi passes ( on the street going to work )this morning for less than a quarter mile, and it sucked up almost half of the little tank. i've been playing with this stuff for three days now and it seems i have room to turn the wick up more. my only problem is i don't like my boost flashing 24 psi and dropping back to 20-21 psi, because when/if i get up to 24 psi then it'll probably flash 30. that's not what i want.
right now i'm runnin water with a touch of alky that was left in the tank, and i don't think the car feels all that fast with just water. it was screaming on top end with just alcohol, so i think i'm just going to run that.
i have my pump speed set on 6 or 7 can't remember right now, and the stuff comes on at 14-15 psi. i see no instances of knock whatsoever, even when it flashes 24psi. are there any pointers that i may need to know, this stuff seems pretty easy to tune and i want to max it out. i think this afternoon i'm going to turn the pump speed down some to see if i go faster and still get no knock. oh, can to much alky slow you down ( ie. high pump speed )?
MAN THIS STUFF IS FUN!!!!!
