Well, the cam and the bigger turbo will allow more air flow, but if your injectors stayed the same during that swap, your old chip should be fine up to 12-15# of boost at a minimum as the air should still be able to be metered fine and the MAF reading translates to how much fuel it gets. Only if you are exceeding the max MAF reading then does fueling come down to the PE tables, which would need to be increased (new chip) when changing the cam or turbo.
I bet you have a weak coil or ignition module, bad plug wire or something ignition related. For some reason, weak ignitions start showing themselves when a bigger turbo is bolted on, mine did the same thing...would hit 15# and pop thru the intake when I used to run 20# on a smaller turbo fine.....new coil fixed my problem.
