SignUp Now!Originally posted by Sweet6
I will check on that. The only thing is that it sounds like it is coming from the middle to front of the car. But it is hard to say. I need to spend some time on it.
How is everything with the car coming along?
Originally posted by WakkoSS
Reference the '97 Crown Vic....there's a metal stop on the control arms. When you've got the steering turned at the lock and the suspension moves at all, it'll make that horrible clunk. People always stare when I make a hard U Turn in my '99 and it makes that noise. They think the engine's gonna fall out.![]()
Originally posted by arista5
well i had the same noise a while back, this is what fixed it....
when you put the sway bar on i am guessing you did it off the ground, that was my mistake, it needs a load on it, if you have ramps back it on then tighten the swaybar, it needs to be tightend with the load on rather than off.
