coldair85GN
fast85GN
- May 29, 2001
Anyone got one laying around they would sell? 14 bolt and WITH the baffle.
Lemme know.
Lemme know.
SignUp Now!why not hit the local junkyard and pick one off the first g body or b body with a 231 or 4.1 in it that's laying on it's side and pull it off of that?
I have one. It is stock and still on the engine, so I imagine it will have the baffle no matter what. How is 50 shipped? They are big, so It will cost a few to get it to you.
If you or a buddy has a tig, it would be easy to weld in a piece of sheet metal for a baffle. It wouldn't have to even be exactly same shape and size as oem. As long as you have room for pickup and dipstick, will be just as effective. A piece of sheet metal snips would make it easy to cut to proper shape. just a thought
i'm sure someone makes a bolt in windage tray for the Buick V6.
if not, then maybe someone needs to step up and offer one.
After asking several people about that I have reached the conclusion that NONE of the normally aspirated 3.8 or 4.1 cars will have the oilpan with the baffle inside. The baffled oilpan was only used on the turbo motors to keep oil in the pan from splashing up on the crankshaft and rods which would create drag. I already purchased a 14 bolt powdercoated oilpan that looks really nice, but when it arrived I found out it did not have the baffleWould it work..probably..but considering I am planning on this motor running 10's I would rather get the right part and not take the chance..they are a PAIN to change out in the car.
almost every other engine in the world has a bolt in windage tray available for it, so why would one not work in a Buick V6?Bolt in would be a bad idea because that means thru vibration etc, it could come loseWelding one in would be fairly easy though.
