All-
I need advise on what to do.
Met up with a buick specialist mechanic to freshen up my stock motor with 88k miles. I've just conducted a compression test and all cylinders were at 150lbs solid.
I will be taking out the engine and dropping it off at his shop. I will be providing him with all the parts. He will charge for labor $750.00 to do the following:
Replace valve stem seals and valve springs
Replace timing chain and timing cover
Replace water pump
Replace 160 degree Thermostat
Replace rear main seal
Repaint the valve covers, upper intake, plenum etc...
Now, he said he was going to check on the condition of the cam shaft to see if it was worn or as he put it "flat" if so he would put in a roller-cam along with getting the stock irons ported and polished. His quote for this alone is $1,200 dollars labor ONLY.
Is this reasonable? and how far should I let him go with this as far as putting in a new cam assuming the original one is ok?
Replace water pump
