I need all new body bushings + the missing ones, where to get them all?
Yep, that appears to be the one I ordered. 3-4141G
Now for the "missing" ones, where do I find the other hardware for them, such as the bolts? (Or what size are they and I can pick them up at the hardware store?)
GNX bushings have NO bolts. They just perch on the rail (they have an alignment post on them)
The other "missing" ones aren't missing the bolts, the bolts are (usually) there. They're just missing the rubber bushings. Once you get under it and really look, you'll understand.
3 hours is pretty good,, for us humans it'll take a saturday. It's not that hard really(don't be scared) however, watch when you jack the body off the frame(an inch or so) that you don't damage the bumper inserts. Also, do one side at a time, only just slightly loosen the other side.
Useing Poly bushings doesn't make the ride to harsh, or squeaky, that's a old wives tale.. :rolleyes:
There's 7 on each side, and if it looks like one's missing behind the wheel :eek:, especially the PS, then you really need new mounts.
PS: changing the lower front control arm bushings to poly is a big improvement, but takes longer. Also, the front lower frame braces are very effective and immediately noticable.. :p
Thanks Warp and Zam, all my questions answered!
AS far as the bumper inserts, I supposed thats because when lifting the body up off the frame, the bumper inserts go up with the body but the bumpers stay put with the frame right?
If thats the case, I'll just remove the bumpers, I think I read somewhere in the tech articles to remove them since its not that hard to do.
