alwayscode390
 - Apr 2, 2009
Hey Guys.  I have only had the car for 4 days, lol ... and someone is calling me out at work.  He wants to go at it during lunch.  I havent had time launching this car, so if you can give me tips it would be appreciated ( so I can represent us well!!! ).  I am not scared of losing, but of hurting the car.
Here are MY specs:
-150k miles on bottom end, 20k on cam and springs
*Edelbrock Performer RPM cam,lifter,double roller t.chain, and springs
-Razor alky that I am not sure is working, but its hooked up
-KN cone filter
-Nitto Drag Radials 245/50/16 (what pressure should I run?)
-Dyno tune at 320rwhp (I would say 400 crank),
-Flowmaster Exhaust with cat delete .
-MSD 50 lb injectors
-Manual fan switch over ride
-Fuel pressure regulator (adjustable)
-New msd Coil Pack,wires, and ignition module
-MAF translator with LT1 maf
Here are HIS specs:
06' SRT8 Charger with an 08' Engine 10k miles
-Diablo programmer
-Magnaflow high flow cats and mufflers
-Cold Air Kit
-22" x 10" Viper wheels (heavy replicas)
I would guess he is pushing close to 475crank hp
Stock vs Stock Specs:
ME vs. Him :
Weight- 3346 vs 4160
0-60 - 5.3 sec vs 5.3 sec
1/4 mile- 13.4 sec vs 13.5 sec
Seems like it will be REAL close, I just need to launch good and I hope his big wheels slow him down.
We will be racing between 1/8 to 1/4 mile on an unprepped surface. Should I heat them up? I havent tried to burnout with a turbo'd auto before... do I just stomp the brake and push the gas quickly to break them loose?
I did some searching and seen a lot of people stomp the break and slowly push the gas to 2000 rpm for a launch in our cars. Does that sound right?
I am going to top off the oil ( slight rear main leak ), I heard to overfill the tranny by 1/4-1/2 quart to compensate for the sloshing during launch, but should I add some octane booster from the auto store? I am using 93 right now and the tank is 1/2 full.
It will be in the low 30's for the temp... so the turbo should be happy.
Thanks for the tips
			Here are MY specs:
-KN cone filter
Here are HIS specs:
-Diablo programmer
-Cold Air Kit
ME vs. Him :
Thanks for the tips
