Ricky Trussell
- Feb 28, 2003
Well, just from my experience I know that if you use the page up or down rapidly it will mess up your settings somewhere. That is a no brainer, I won't use the page up or down to make changes. Anyway after the first set up you really should not need to make that big of moves.
The spikes that I have had in the idle vs coolant have been with the laptop off. So this looks to be something else. I probably will send my ecu back for testing to make sure it is okay. I have waited to see if I could get some tuning issues corrected, which I have not been able to do. WOT is easy, low speed has not been for me. The 2000 rpm cells must have 30-60 higher VE numbers to get low correction as the other cells with the same A/F setting. I do not have anyone close that I could swap ecu's to see if that is the problem.
