Warm the car up completly, Then open up the Throttle Follower screen and adjust the throttle blade until the IAC is 10-20 (this will be the ball on the far left side of the screen). If open the throttle blade, the ball will go down. If you close it, the ball will go up.
Once you have the IAC set correctly you will need to redo the TPS Calibration.
