My IAC is probably shot to sh*t right now. typical surging revs dying out at a stop light. And maybe my EGR Diaphragm too. I pushed up on the diaphragm and it didnt die out, indicating a leak. I cleaned out the IAC housing and IAC tip with MOC brand carb cleaner. and reset the IAC and TPS. still surging, no CEL, no codes. Checked for vac leak, none what so ever. I noticed on John Spinas site that the IAC he has in stock is an 84-87 Item. can 84/5 use an IAC for 86/7 TRs? John Pearcy has year specific, though the 84/85 is much more. Also, what vendor sells the 84/5 EGR Valve? John P has the 86/7 EGR Valve in stock. can 84/5 use the 86/7 EGR valve? they look kind of the same.
HELP!
