check the wires and plugs, alot of things could cause a miss at higher rpms @ 4900 rpm is the miss occuring under high boost or low boost? check grounds! also unplug the WG and take it for a ride and get on it and see if it still does it @ 4900 rpm without being on boost also after 4900 rpm does it get better or worse and is your FP rising like it's suppose too?
