LEGACY_GN
- Apr 16, 2007
I always thought it was block learn mode. Learn something new everyday. Thanks for the info
SignUp Now!Any other ideas? No vacuum leaks, new IAC didn't fix, new o2 made it intermittent. Only does it at idle.
Yes, you never clarified what the MAF reading was at idle when it's acting up. You mentioned some numbers earlier in the thread of something in the 40-50 range which are impossible numbers at idle!!!!!! The MAF should be 5-6 at idle if working properly.
If the maf isn't reading somewhere between 4-6 at idle, throw it away.
??It's definitely running out of gas when the bl drops to 115.
It's definitely running out of gas when the bl drops to 115. ?
