We 'scoped the engine and the noise (which does speed up with the engine RPM) appears to be coming from the top-front-driver's side of the engine. Or so a big piece of heater hose would have us believe
Soooo, in the pursuit of the "knock" we are looking at the simple things first: Accessory bearings
Among these are the idler pulley... when examining this puppy it seems that the pulley itself has a lot of fore-aft play in it. How much is acceptable? I have a second/back-up pulley that has about 1/2 as much play in the pulley itself. Is this a rebuild it, or buy a new one situation?
Also, I understand that a worn alternator can make a "knock" as well... my alternator was getting unusually hot in just a few minutes of run time. This MAY be because the battery is a bit lower in charge than it should be and consequently the charging system is compensating. Could a bad alternator bearing = excessive case heating?
<Note: The torque converter bolts were checked & found tight, and the flywheel appears crack free>
Thanks,
Thanks,
