with key on engine not running the volt idiot lamp should be on, if its not odds are your charge circuit is incomplete and the alternator is not exited so it has no output unless your dash lamp socket has the resistor on back of that lamp (provided the contacts to the back are good and its just a bad bulb )
caspers field fix would help if no lamp
