?ignition break up starts at 4500rpm
Bob
I need the install directions for my box
Instructions are long gone
Was installed I think by cal long ago
I don't see all these wires and splices to disable it
Is there any easier way to remove it?
The bailey side with the most wires that has a gray and a white wire at ECM and those two bailey wires splice into ECM and other white wire runs into harness
Are these the two wires I splice back together?
the manual can be downloaded here:
http://2step.bailey-eng.com/
to remove, look in the fusebox under the drivers side of the dash, there should be a cable plugged into the CCCI fuse location. remove that and install a fuse.
on the signal cable, if the white and gray are spliced into the ECM harness, disconnect them and reconnect the harness wire (it will be white)
Bob
Clay, I think I installed that. I will be out of town for a couple weeks with the new job but can help you when I return now that I'm caught up with life lol
