ignition cylinder just spins!?
Chatmanboy
Try to change it and the new on does the same. How do I fix it need help. Cant start the car
Look to see if the connecting rod that goes on the outside of the column, [lower end], is pulling when you turn the key. If not, it's up in the top of the column, and the wheel has to be removed to see whats up.
Well this part is what broke
