ignition cylinder?
Warped
No helmet required!
Key won't turn to accessory. Any other ideas before I replace the obvious? Car only has a couple hundred thousand miles on it. Don't know why it would be going out so soon.:cool:
Most likely a broken ignition switch rack. It's a pot metal part and when it cracks or breaks it will hang up inside the column. You should be able to find a new part hanging down on the Help Rack at the parts stores.
