I just put my car back together with a new cam and I got a code 42
All grounds were just cleaned and put back on.
Non-GM coil pack and ingnition module have been used for the most part I have had the car with no problems (minus some other issues) and I have never gotten a code 42. I swapped back to the original GM stuff and the code is gone, but I get a miss very often. The check engine light flashes on that instant for the miss and then its gone? No codes are being kept as I am monitoring with the scanmaster.
I am trying to find someone close with a coil/ignition tester...
Is the coil pack/ignition module and strong possibility?
I recently installed a Translator + before the cam swap and didn't get a code 42 or the miss and CE light, I took my time installing it, but haven't rechecked the wiring since.
I am not real sure where to start looking, I want to start driving her again
TIA
Ron
TIA
Ron
