Ignition pros???
They will work if you have converted to a Type II ignition module. If you are running the stock Type I module, NO.
Ok is this something easily done or even worth doing as far as an upgrade?
The change over is easy but not really worth it. I put a Type II on my 86' GN and saw no difference in performance. The stock Type I system works quite well. To change over you will need an adapter plate.
