Well I miss driving my GN. It has over 144K on it, Stock Timing Chain, and stock Valve Springs. I have been searching the boards and reading the horror stories of what those wonderful plastic pieces of gear do to an oil pump. (Thats why I dont drive it) So Im going to attempt it!!
I figure since Im tearing into it, I figured I would change...
The Water Pump, Belt, install RJC Pullies, Valve Springs, Poston Headers, Cross-over, DP and TA-49. Then I guess Ill have to install 42lb injectors and a chip.
Should I change to a Caspers Cam sensor? Should I install a new Crank Sensor? What other "things" should I do while its tore this far down?
(I should just pull the damn thing and get it over with)
Thanks for the help.
Craig
Ill have some pictures up soon. ( I hope)
Craig
