Im replacing stuff on my car need ideas
charleslong
Well so far i just odered a thrasher chip blue top. What else do you guys recommend?
these are the mods that were on the car, including the ultrachip that i will be taking off.
spark intensity controller, 70mm throttle body, aluminuim ported/polished heads, stock turbo, boost controller, cold air intake, 3" flow master exhaust, knock guage, temp, turbo guage.
Umm...with the heads and big TB I would get a 44 or 49 turbo next. Maybe even a 60-series.
thanks guys,
how much would those turbo's mentioned above cost, and will there be a significant difference between any on pump gas, and over a stock turbo?
thanks in advance guys
$700 for a turbo, at 15psi though you will probably not see any difference. I would get an SMC alky kit and max out the stock turbo before going to a bigger one. Only over 20psi will there be a difference
