I'm selling this car if I can't get it running right
I have an '87 GN with 72k miles, original paint, as nice a car as you will find inside and out. The car was purchased with a bad engine and a 1k built engine was purchased to take it's place (GN1 alum. heads, 206/206 hyd. roller, roller rockers, girdled crank, ported plenum, etc.). When engine was installed it was scary fast (481 rwhp on dyno) and ran great. Then the car sat up for some few months when my son got a Ford Lightning to play with, and was jump started a few times. Then the car runs like it's in limp mode or something, no power, knock retard gauge went off when under load and applying gas.
I bought the car from my son knowing this. When he drove it over to my house it backfired one time only, it had never done that before.
I get the car to the house and then it doesn't want to start. I've replaced the crank sensor, the cam sensor, the electronic spark control sensor, and ohm'd out 2 coil packs as good and had 2 ignition modules checked as good at O'Reilly's. I even put in a new ignition switch. The plug wires are new and good with new plugs. The car has Scanmaster 2.1 and Direct Scan, also Translator + 6.? and a 3.5" MAF.
The car will start sometimes cold and 5 min. later not start at all and it wants to backfire sometimes attempting to start.
I'm just about fed up with this car and if someone can help me it would be greatly appreciated !!! I have even tried a different ecm and another chip, all to no avail. It's a beautiful car and drives like a dream when it is running.
I think I may sell the car even if or when I get it running properly again.
Please Help Me!!
![Confused :confused: :confused:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png)
Please Help Me!!
![Mad :mad: :mad:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f621.png)
