TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
Trans has 22,000 miles on it and has never been rebuilt. Running a red stripe converter, hardened stator, Level 10 shift kit, trans cooler, Stage Right trans brake, aluminum deep pan. Frequent fluid and filter changes. Recently replaced the TCC solenoid and when I dropped the pan found a small section (maybe 3/8" long)of what looked like a part of a snap ring on the magnet. Had some small bits of shiny metal in the pan also. Just did a fluid drain to check on what was in there after about another 1000 miles and had some small bits of metal shavings in the pan. Is this a sign of impending doom or what. Tranny shifts as hard as usual, no slipping etc.
If it is on the way out I would like to get one of Bruces trannys but we are on opposite coasts. Bruce, do you have distributors of your trans out here in the New England area or are complete transmissions only available from you?
