in-line water pump?
Louster38
Does anyone know, if such a thing exists, where I would look for one? In-line is not necessary, but it needs to be electric and capable of flowing decently and be able to handle water/coolant. The type of thing you might use for a liquid intercooled system.
Summet sells in-line pumps or you could get the mizer pump that replces the factory water pump.
I have an RV pump I used with my liquid IC. I don't know how it would work on the engine though.
hey do you guys have the part number for them
Flo-Jet.
RV pumps, and Yacht pumps. Yachts use high volume and high pressure "wash down" pumps to clean the hull. More than enough flow. Expect to spend $90 or so. Wash down pumps are designed to pump water with chemicals in it, like bleach, or simple green, or strong marine soap. Good units!
