After being at the shop the verdict on my block came in today. The crank is still good, the heads are cracked, so here is where I am a little stuck. My goal is a mid 10s, street car with the ability to eventually hit the 9s. Im thinking of going to aluminum heads, what do you all recommend. The internals will be strong but should I worry about the stock crank? Should i change the compression ratio? and what size cam do you guys recommend? It will be a roller setup.
