In-tank Pump E85 question
Mine runs feed from tank along frame over bell
housing to rail w/ filter.............return runs parallel along frame to tank vent connect at sending unit. 8 an feed with filter at tank and at rail. Return directly to tank ( eliminating the over axle connections) ! Easy to maintain so far
What are you guys running inside the tank as the submersible hose? Using the hose that comes with the DW kits? Arequip blue hose?
